Hi, I've installed correctly autocad 2010 for first time but when I'm triying to run the program a dialog box appears showing me the text "Status License [2.10.0]". I can't use "the run product" button. This is the first time I installed a autodesk product so, I don't understand why the program show me that box. ¿¿¿Expired??? is imposible, I don't expired the trial time (30 days).
What is the problem? I have a Windows Seven and a Windows Vista (2 PCs)
Thank you in advance
Can you send the .log file(s) from this folder “C:\ProgramData\Autodesk\Adlm” and a screen shot of the error?
Douglas Lauritsen, Autodesk Product Support
Hi Douglas,
This is the screenshot's problem, I have no .log files in that folder, only one xml file in the es-Es subfolder with the traduction of possible errors.
There is no screen shot attached. Can you repost it?
You need to select Activar to activate the product.
