Installation & Licensing
AutoCAD 2010 Startup Issue
1 REPLY 1
2048 Views, 1 Reply
When I start AutoCAD, it runs through the splash screen, and briefly shows me the AutoCAD program before crashing. I nosed around this site and found my error log, which shows the issue is with two files, AdlmIntLicense.cpp and AdlmIntNWFBLicense.cpp. I have tried the ideas already posted on the Autodesk Knowledge Base, including reinstalling, checking a registry key value, and repairing my .NET Framework.
Below you will find the error log in question:
5272 2013/07/08 13:41:32 Reason=Fatal error
5272 2013/07/08 13:41:32 ComputerName=W72C-CNU2024SWW
5272 2013/07/08 13:41:32 OS=5.1.2600.Service Pack 3
5272 2013/07/08 13:41:32 File=AdlmIntLicense.cpp,Line=851
5272 2013/07/08 13:41:32 VendorID=10 [CASCADE]
5272 2013/07/08 13:41:32 VendorError=6 [Error reading decrypted information]
5272 2013/07/08 13:41:32 File=AdlmIntLicense.cpp,Line=852
5272 2013/07/08 13:41:32 AdlmIntError=2 [Failed: Internal programming error]
5272 2013/07/08 13:41:32 File=AdlmIntNWFBLicense.cpp,Line=647
416 2013/07/08 13:41:37 Reason=Fatal error
416 2013/07/08 13:41:37 ComputerName=W72C-CNU2024SWW
416 2013/07/08 13:41:37 OS=5.1.2600.Service Pack 3
416 2013/07/08 13:41:37 File=AdlmIntLicense.cpp,Line=851
416 2013/07/08 13:41:37 VendorID=10 [CASCADE]
416 2013/07/08 13:41:37 VendorError=6 [Error reading decrypted information]
416 2013/07/08 13:41:37 File=AdlmIntLicense.cpp,Line=852
416 2013/07/08 13:41:37 AdlmIntError=2 [Failed: Internal programming error]
416 2013/07/08 13:41:37 File=AdlmIntNWFBLicense.cpp,Line=647
1 REPLY 1
m_latz
This could be a problem of a broken "CascadeInfo.cas" file.
You can find the file in:
Windows XP in "C:\Documents and Settings\All Users\Application Data\Autodesk\ADLM"
Windows 7 in "C:\ProgramData\Autodesk\ADLM
delete the file and AutoCAD should start again.
regards
Markus
Administrator Productivity
