Installation & Licensing
Autocad 2010 client's can't get network license
7 REPLIES 7
Message 1 of 8
A4E
762 Views, 7 Replies
We have autocad2010 and have been using the LMtools successfully for years until upgrading to a 2012 windows server and getting new desktops/laptops a month or so ago and got an upgraded 2011 license.  On friday we lost the ability to pull licenses and have run through the various forum directions.  Note, we are not IT system administrators, nor do we have one - so much of the tech lingo is tough:
We checked to ensure the License is working correctly - and yes, says we have 6 licenses with 0 being used.  We upgraded the LMtools to version 11.11 today, however when running the system diag it still says 11.5.
We changed our environmental variables to go directly to the server and to extend the timeout period
Our client clocks seem to be sync'd up with the server date/time
we pinged the server, and all goes well (and looks to be a IP4 connection - whatever that means)
we tried going through revit 2010 - using the licensing tool - but it can't find the server either by it's name or IP address
When we get the warning "unable to locate license" the error comming up is 0.0.0 - very helpful
We have tried 3 desktops and 1 laptop, all getting the same error.
HELP!!!
Architect
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: A4E
Delete your Cascade.cas file and try again.  If you upgraded your license to 2014, then Subscription no longer contains 2010.  Only 2013, 2012, and 2011 are leased.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 8
A4E
in reply to: TravisNave
tried that - didn't work (plus this issue has shown up for multiple computers mind you) our license given to us by autodesk was 2011, we are using 2010 autocad, the server is windows 2012 64, and the clients are windows 7 64
Message 4 of 8
TravisNave
in reply to: A4E
See my IPv6 link.
Autodesk Forums:
Message 5 of 8
A4E
this is out of my experience level - but when I ping I get what looks to be the IPv4, not the IPv6 nomenclature
Message 6 of 8
DarrenP
in reply to: A4E
i suggest getting with the person that handles this and make sure the license manager is running
DarrenP
Message 7 of 8
TravisNave
in reply to: DarrenP
I agree with Darren.  Also, I have found that on many Server 2008 R2 and newer, the NLM 11.11 doesn't always work and the adskflex.exe fails.  Replacing it with the 11.7 or 11.5 version resolves this.
Autodesk Forums:
Message 8 of 8
A4E
thanks all - ended up working with autodesk tech support - it was our license file given to us by autodesk for the server upgrade - it was set up to work with 2011, when our software was 2010. However - we have a new license file now, and all is well
I will keep an eye out for the failing adskflex if it happens
Administrator Productivity
