Civil 3D 2010 is available in 32 Bit only. For this reason only the 32 Bit version of the Object Enabler has been released.
On other side, is not possible to install AutoCAD 2010 32 Bit in a 64 Bit machine.
However, is possible to visualize the Civil 3D objects in AutoCAD 2010.
In Civil 3D 2010, set the variable PROXYGRAPHICS to 1, before saving the drawing.
When you open the drawing in AutoCAD 2010, the Civil 3D objects are visible as proxy objects.
Regards
Antonio Barroca
Autodesk Product Support
We appreciate your quick
feedback on this forum!
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks:
http://upandready.typepad.com
Antonio Barroca
Product Support Specialist
Autodesk, Inc.
