First solution :
Upgrade your FlexlM on your server.
2007 needs FlexLM version 10.8
Second solution :
Remove Line Plist if your FlexLM is older than 10.8
Franck Hervet
www.aricad.fr
a écrit dans le message de news: 5348344@discussion.autodesk.com...
We are trying to add three Network Licenses to the existing installation of
NLM. The NLAs are installed and the server also shows the same. But while
installing the client AutoCAD gives following error.
ERROR - [1.5, -18]
A valid license could not be obtained by the network License Manager. Try
Again. If you are still unable to access licenses contact your system
administrator.
