I have had trouble re-installing my AutoCad. Now it looks like I made it, but the software became really unstable. I can open dwg documents and even make simple changes but actions such as hatch crashes AutoCad every time.
I have removed and re-installed AC several times, nothing changes.
What can I do?
Solved by TravisNave. Go to Solution.
Are you using a supported operating system? Have you updated all the service packs?
OK I finally googled the supported systems. I see the problem now. I have Windows 7 on this computer, no wonder AC is unreliable. Looks like I have to purchase updated version. Too bad, as I only need it occationally.
Service pack updates will not fix this problem, I suppose?
