Installation & Licensing
AutoCAD 2004 SP1 patch
17 REPLIES 17
Message 1 of 18
LynnOmland
2646 Views, 17 Replies
I need the AutoCAD 2004 SP 1 download patch unlocked ver. Can any one help
17 REPLIES 17
Message 2 of 18
jessica.t
in reply to: LynnOmland
Hi LynnOmLand and welcome to the Autodesk Community!
We were able to locate the file that you're looking for, I've sent it to you in an email as the zip file is too large to attach. However this is a very old file and is no longer supported and therefore we cannot guarantee a successful download, but we are very hopeful! Please let me know how it goes. Thank you!
Jessica Thrasher
Message 3 of 18
LynnOmland
in reply to: jessica.t
Hi Jessica,
I do not see how to get the file from your email, Sorry
Lynn
Message 4 of 18
jessica.t
I use Outlook, but when I double click the file it gives me the option to Save or Open. Are those options not available for you? Which email provider are you using? I double checked my sent email to you and the file is attached.
Jessica Thrasher
Message 5 of 18
LynnOmland
Hi Jessica,
I spoke to my IT guy, He tells me all .EXE files are blocked by our firewall.
Please send it to my home email as follows.
lynnomland@gmail.com
Thanks again for your patience and help.
Lynn Omland
Message 6 of 18
jessica.t
Thank you! I just forwarded the email to your personal account with the zip file attached. I hope this works for you! Please let me know!
Jessica Thrasher
Message 7 of 18
LynnOmland
Hi Jessica,
This is Unbelievable I still can't get your email.
Can you double check my address, and did it come back to you.
Can you try one last time. If this does not work I will forget about it.
Thanks again for all your help.
Lynn Omlamnd
Message 8 of 18
jessica.t
No worries, I just sent it again. Perhaps check your spam folder?
Edited: I just received an email back saying that the delivery failed because my email to you presents a potential security issue. Is there anyway you can alter your email security settings?
Jessica Thrasher
Message 9 of 18
LynnOmland
Hi Jessica,
What has worked in the past here at my job, we change the .exe extension to a .txt extension and email it that way.
When I receive it I change the file back to a .exe again. I can't change the fire wall for my personal email.
Can we try that?
Lynn Omland
Message 10 of 18
jessica.t
I just sent it again and changed the extension but it's a zip file, not an executable so I'm not sure if this will work but let me know.
Jessica Thrasher
Message 11 of 18
LynnOmland
Hi jessica,
I am ready to give up!
For some reason your emails are not getting through.
Can you give me the link where this zipfile is located, and maybe I can download it myself.
If this is not possible, I will thank you for your help and I will give up.
Lynn
Message 12 of 18
jessica.t
I'm sorry, Lynn but this file wasn't derived from a link that I'm able to send. It was dug out of the archive.
But there's one more option! I just sent you the zip file via Autodesk 360. This is our free online cloud service that will allow us to share documents. You should have received an email notification. Please let me know how it goes! Fingers crossed! Smiley Happy
Jessica Thrasher
Message 13 of 18
LynnOmland
Hi Jessica,
The Zipfile showed up!
When I try to install the update it stops and asks for the original AutoCAD 2004 disk.
I do have the original disk that was used to install the software.
When I put in the disk and click OK it will not continue instalation. It says it can not find valid file to continue.
Where on the Original disk can I find the file it is looking for.
Thanks again,
Lynn
Message 14 of 18
LynnOmland
Hi Jessica,
The zip file finally came.
WhenI try to install the patch it stops and asks for the AutoCAD 2004 disk.
I do have the original disk and inserted it in the CD drive and click OK.
It will not continue the instalation because it can not find the file to continue.
Can you tell me what it is looking for and where to point to it.
Thanks again for your help
Lynn
Message 15 of 18
jessica.t
Hi Lynn,
Glad you received the file! Could you send a screenshot of the exact message you're receiving? Thank you!
Jessica Thrasher
Message 16 of 18
LynnOmland
Here are the screen shots
Message 17 of 18
LynnOmland
Hi Jessica,
Here are the screen shots. Attached.
Lynn
Message 18 of 18
jessica.t
Hi Lynn,
This appears to be a Microsoft error, could you try this solution from their website to see if it resolves the issue? Thanks!
Jessica Thrasher
Administrator Productivity
