dstein,
From the AutoCAD 2005 "Acad_NAG.pdf" on page 79, item 7:
"In the Program CAn Run list, select Only When a User Is Logged On, and then
select the User Input Required option."
Beyond these two settings, yes, mine is the same. This is the problem
aparently, because I do not want to run this in front of the user and I
don't want it to allow input.
This makes real the scenario of "user logs on and starts to work, then
realizes that AutoCAD(prev ver) is gone(having been uninstalled while they
were not logged in), calls IT support wondering why they cannot work, then
calling up the manager chain to complain that they cannot work."
If I understand this right, I am then forced to do very small clumps of
collections to install to since having a whole office deploy in this manner
is complete suicide.
I cannot believe Autodesk has made a package that must be installed while a
user is "active" on the machine.
Any method that requires user intervention at the workstation directly
drives up the cost of implementation. This makes it nearly prohibitive to do
a planned weekend replacement without having people onsite to run around and
log onto machines. $$$$$ and time.
I will presume since you have done it with scripts that all of your users
are admin on the workstations, yes? The vast majority of ours are not and we
like it that way.
John
