Installation & Licensing
AutoCAD 2002 on Windows 7, 64-bit PC
2 REPLIES 2
karpathios20
10825 Views, 2 Replies
The company I work for has AutoCAT 2002 LT version. I am trying to install it on a Windows 7, 64-bit PC and I face the following issues:
1. During the installation, the following error appears: "There has been an unexpected error with the license management system. Please contact your system administrator or dealer. Error [436:4:1]". See the first attachment for further info. However, the installation finishes successfully after I click on the OK button.
2. When I attempt to run the installed successfully AutoCAD, the following error appears: "Error: loading cdilla dll !!". See the second attachment for more info. When I click on OK button, it crashes (AutoCAD doesn't even start actually).
FYI, the licence key for the particular version of AutoCAD is generated as follows: If I had it installed and used it on PC A, I should generate a security key from PC A, in order to make it available on PC B. I had to input this key on PC B, in order to use it. After this procedure I couldn't use it on PC A, until I regenerated a key from PC B and input it on PC A.
2 REPLIES 2
asburyj
in reply to: karpathios20
Even windows XP was fairly new with AutoCAD 2002 came out so the chances you will get it to run on windows 7 are slim. You best bet will be to run a windows XP mode virtual system on your windows 7 computer and install AutoCAD 2002 on there.
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Jeffry Asbury
pendean
... Or buy this product that seems to help users like you: www.longbowsoftware.com
Administrator Productivity
