Installation & Licensing
1052 Views, 3 Replies
AutoCad 13 Activation
Hi... The problem with me and the activation of the programm started when the activation window refuses to load and stays blank.. But I have manage to surpass this problem by using the url and inserting the activation code AutoDesk sends me... And is activated, at least that's what is displayed on my browser window, but qafter I start the programm again I have to activate it! Again again and again... Now the trial has expired, what do i do next... Also I have encounter the exact same problem with 3DS Max...
Thanks in advance
3 REPLIES 3
Alfred.NESWADBA
first disable all defending software you have (antivirus, firewall, ...). Then right-click the AutoCAD-icon on your desktop and use the option "start as administrator" and try it again.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Thanx but it doesn't do anything different... In the atachments I have in the pdf the url that coresponds to the first activation window, the small one, and the jpeg is what appears when I do the manual activation on the browser.
Alfred.NESWADBA
you should contact Autodesk directly. The message I see in the PDF tells me that you have done (many) more activations than licenses bought. If that comes from problems because of not saving the activated status then it may be not your fault, but the database at Autodesk sees more requests then ordered .... so the time will come up that the activation-center will ask questions.
Call your reseller or Autodesk directly and describe the state where you are.
Sorry, - alfred -
Alfred NESWADBA
Administrator Productivity
