Hi i recently downloaded the trial version of auto cad 2014.
The downlad was successful but the installation is a problem.
After i clicked to agree to the install the software i receive an error message via a dialog box saying the followings:
C:\Users\JohnJohn\AppData\Local\Temp\_AIEE64.TMP\setup.exe /s
C:\Autodesk\AutoCARD_2014_English_Win64bit_dlm\ /temp
C:\Users\JohnJohn\AppData\Local\Temp\_AIEE64.tmp\ /Second Run /lang en-us /FirstRunThreadId 5960
After I click OK (from the dialog box) then my whole installation disappears. Then i have to install again.And kept on seeing the same problems with the same message via a dialog box saying the same message.
Can someone help me?
Here are my specs for my laptop:
System Information
Time of this report: 11/15/2014, 23:15:31
Machine name: JohnJohn
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120330-1504)
Language: Maori (Regional Setting: Maori)
System Manufacturer: Hewlett-Packard
System Model: HP ProBook 450 G1
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5-4200M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3978MB RAM
Page File: 2582MB used, 5370MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0416&SUBSYS_1942103C&REV_06
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: SDC4751
Native Mode: 1366 x 768(p) (59.987Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 9.18.0010.3272 (English)
Driver Version: 9.18.10.3272
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/8/2013 07:44:58, 8653312 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4756-11CF-447F-4839BBC2C435}
Vendor ID: 0x8086
Device ID: 0x0416
SubSys ID: 0x1942103C
Revision ID: 0x0006
Dean is right. This error is also compounded by anti-virus programs. Especially Trend Micro, Avast, and Norton. Temporarily disable these when installing.
