Auto CAD 2016 in Windows 10
Message 1 of 52
Hello guys;
When I install the AutoCAD Electrical 2016 on my PC (Windows 10 Build 10041) i got this error:
Install AutoCAD Electrical 2016 Core Failed Installation aborted, Result=1603
Replies (51)
Message 2 of 52
jeffrey.sin
Hi @Anonymous
Welcome to the Community! Kindly check the information provided in the links below, this should help to troubleshoot and resolve the issue you are having.
Error 1603 during installation of Autodesk software
How to remove and reinstall the Microsoft .NET Framework
Do let us know how it goes and if the suggested solution resolves your issue. Thanks,
Jeffrey Sin
Autodesk Customer Support
Message 3 of 52
Thanks for the support.
I got back to the previous error.
Message 4 of 52
windows 10 isn't a supported OS
try installing on a supported OS and see if you get the same message
Message 5 of 52
TravisNave
@Anonymous I was able to install AutoCAD 2016 on Windows 10 without any issues.  You need to add .NET Framework from the Control Panel > Programs & Features > Add Windows Components.
That should help.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 6 of 52
Thanks @TravisNave
Please help more for how can I add .NET Framework and install AutoCAD on Windows 10.
Message 7 of 52
TravisNave
Looks like it is installed. See my link on how to edit your setup.ini file to ignore the check for .NET.
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Autodesk Forums:
Message 8 of 52
the above should work
Message 9 of 52
@TravisNave
I followed all the above instruction but it did not work.
My error is: Install AutoCAD Electrical 2016 Core Failed Installation aborted, Result=1603
Message 10 of 52
There is no way to install AutoCAD on Windows 10?
Message 11 of 52
TravisNave
Of course there is.  I have installed on Windows 10 without any issue.  Post your installation failure log.  Just keep in mind that Windows 10 is not a released or supported OS yet.
Autodesk Forums:
Message 12 of 52
Hi @TravisNave;
Please complete instructions for installation.
Thank you.
Message 13 of 52
TravisNave
Please post the whole log as it will help determine if there are other
issues.
Thanks.
Autodesk Forums:
Message 14 of 52
Message 15 of 52
TravisNave
You might have to add .NET Framework 4.5 manually from Microsoft first.
Autodesk Forums:
Message 16 of 52
@TravisNave
 Thanks, But How can I add .NET Framework 4.5 manually from Microsoft?
Message 17 of 52
TravisNave
Try Windows Update or just go to Microsoft.com and put in .NET Framework 4.5 and go to their download page.
Autodesk Forums:
Message 18 of 52
@TravisNave
Windows 10 by default, in .NET 4.6 and when I want to install version 4.5 gives the error:
"Same or higher version of .NET Framework 4.5 has already been installed on this computer."
Message 19 of 52
TravisNave
Perfect.  Modify the setup.ini to ignore the prerequisite check for 4.5 then.
For more information on this process, please see my KB article here:
Autodesk Forums:
Message 20 of 52
@TravisNave
Thank you for support.
This is my original setup.ini file, I think don't need for edit.
