I downloaded autocad 2010 last night. But when i go to open and use the program, it prompts me to submit an activation code. It says my 30 day trial has expired and i need that code for it to work. Is there a way where i can get this activation and serial code?
thanks
You are missing a lot of information in your problem description.
Where did you download the software?
Are you a student?
If so, your personal Serial Number for activating the software should be on the student community.
Otherwise if you purchased the software you should contact your VAR for the serial number.
I am a student and it is a registered autodesk student version. It says they are currently out of serial numbers for this product. Is there any way around this to get autocad working?
thanks
Use all zeros to install while you wait for your serial number to be assigned.
When your serial number is assigned simply start the program and click Activate rather than Trial.
Oh wait, you say your 30-day trial has already expired? Did you have this installed previously?
You will need to email the student community and request generation of your serial number.
