Hi, I try to install AutoCAD2012 but the installation is failed. It shows some message.
2013/3/10:21:18:08 Jeremy Cheng JEREMYCHENG-PC === Setup started on JEREMYCHENG-PC by Jeremy Cheng ===
2013/3/10:21:18:08 Jeremy Cheng JEREMYCHENG-PC Launch
2013/3/10:21:18:17 Jeremy Cheng JEREMYCHENG-PC PageOpen LaunchDialog
2013/3/10:21:18:35 Jeremy Cheng JEREMYCHENG-PC PageOpen LicenseDialog
2013/3/10:21:18:38 Jeremy Cheng JEREMYCHENG-PC PageOpen ProductInfoDialog
2013/3/10:21:19:18 Jeremy Cheng JEREMYCHENG-PC PageOpen ProductSelectionDialog2
2013/3/10:21:20:10 Jeremy Cheng JEREMYCHENG-PC PageOpen FullProgressDialog
2013/3/10:21:20:10 Jeremy Cheng JEREMYCHENG-PC Installing .NET Framework Runtime 4.0 Language Pack: C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1028.exe /q
2013/3/10:21:21:31 Jeremy Cheng JEREMYCHENG-PC Install .NET Framework Runtime 4.0 Language Pack Succeeded
2013/3/10:21:21:31 Jeremy Cheng JEREMYCHENG-PC Installing DirectX Runtime: C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\3rdParty\DirectX\DXSETUP.exe /silent
2013/3/10:21:22:21 Jeremy Cheng JEREMYCHENG-PC Install DirectX Runtime Succeeded
2013/3/10:21:22:21 Jeremy Cheng JEREMYCHENG-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/10:21:22:31 Jeremy Cheng JEREMYCHENG-PC Install FaroSDK Succeeded
2013/3/10:21:22:31 Jeremy Cheng JEREMYCHENG-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/10:21:22:58 Jeremy Cheng JEREMYCHENG-PC Install Autodesk Material Library 2012 Succeeded
2013/3/10:21:22:58 Jeremy Cheng JEREMYCHENG-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/10:21:23:36 Jeremy Cheng JEREMYCHENG-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/10:21:23:36 Jeremy Cheng JEREMYCHENG-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/10:21:23:57 Jeremy Cheng JEREMYCHENG-PC Install Autodesk Content Service Succeeded
2013/3/10:21:23:58 Jeremy Cheng JEREMYCHENG-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\x64\zh-tw\acad\acad.mst;C:\Users\JEREMY~1\AppData\Local\Temp\_AIB01C.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - Traditional Chinese\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/10:21:28:43 Jeremy Cheng JEREMYCHENG-PC Install AutoCAD® 2012 Succeeded
2013/3/10:21:28:44 Jeremy Cheng JEREMYCHENG-PC Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\JEREMY~1\AppData\Local\Temp\_AIB01C.tmp\_la6702.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - Traditional Chinese\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/10:21:32:20 Jeremy Cheng JEREMYCHENG-PC Install AutoCAD® 2012 Language Pack Succeeded
2013/3/10:21:32:20 Jeremy Cheng JEREMYCHENG-PC Installing Autodesk® Inventor® Fusion 2012: TRANSFORMS="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\x64\zh-tw\InventorFusion\InventorFusion.mst;C:\Users\JEREMY~1\AppData\Local\Temp\_AIB01C.tmp\x64\InventorFusion\InventorFusion-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Users\Jeremy Cheng\Desktop\AutoCAD_2012\" INSTALLDIR="C:\Program Files\Autodesk\Inventor Fusion 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/10:21:35:16 Jeremy Cheng JEREMYCHENG-PC Install Autodesk® Inventor® Fusion 2012 Failed Installation aborted, Result=1603
2013/3/10:21:35:38 Jeremy Cheng JEREMYCHENG-PC Rollback AutoCAD® 2012 Language Pack Succeeded
2013/3/10:21:36:32 Jeremy Cheng JEREMYCHENG-PC Rollback AutoCAD® 2012 Succeeded
2013/3/10:21:36:40 Jeremy Cheng JEREMYCHENG-PC Rollback Autodesk Content Service Succeeded
2013/3/10:21:37:13 Jeremy Cheng JEREMYCHENG-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2013/3/10:21:37:30 Jeremy Cheng JEREMYCHENG-PC Rollback Autodesk Material Library 2012 Succeeded
2013/3/10:21:37:33 Jeremy Cheng JEREMYCHENG-PC Rollback FaroSDK Succeeded
2013/3/10:21:37:33 Jeremy Cheng JEREMYCHENG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/3/10:21:37:33 Jeremy Cheng JEREMYCHENG-PC Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
Please help me!!
Your AutoCAD is installing fine. But when Fusion fails, it rolls back the entire suite. During your installation, uncheck the installation for Inventor Fusion. You do not need it. In fact, uncheck anything else that you don't need and you should be good to go.
