Installation & Licensing
Authorization window is blank
28 REPLIES 28
Message 1 of 29
17783 Views, 28 Replies
I have got the same problem -Register today form is blank and shows only two radio buttons- I m useing 3dmax 9 on windows 7 home premium.
and i used these settings. but it is not working.
"Solution:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=6404339&linkID=2475323
This issue can occur if Active Scripting is disabled for the My Computer zone.
To enable Active Scripting
On the Windows (Start) menu, click Run.
In the Open dialog box, enter REGEDIT and click OK
In the Registry Editor, find the following subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0
Double-click the 1400 value.
In the Edit String dialog box, under the Value data field, enter 0.
Find the following subkey:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0
In the Edit String dialog box, under the Value data field, enter 0."
i have attached the Register today blank form pic
Please someone help
28 REPLIES 28
Message 21 of 29
joane.bonghanoy
Hi nayandeepak551,
Do Private Message me your Serial Number so we can check further on our end.
Joane Bonghanoy
Message 22 of 29
Cheeers!! Really workedSmiley Very Happy
Message 23 of 29
TravisNave
Please do not post personal data here in the public forum.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 24 of 29
Good evening,
I am trying to activate my autodesk account, however I got a blank (not loading) screen.
Is there any easy way to fix it please?
It has been about 3 hours I am trying to activate my software (3DSmax) without success and it is a bit discouraging.
Thank you in advance for your help.
Message 25 of 29
s3304885
I have just tried to register autocad 2014 which I downloaded, but the autodesk registration box comes up blank, nothing at all and the whole process freezes.  I have checked for the L file and it isnt there.
Very disappointed as had no difficulty with the older version, please help
Message 26 of 29
jessica.t
in reply to: s3304885
Hi Ian and welcome to the Autodesk Discussion Forums!
Have you tried this working solution?
I apologize for your troubles but I hope that helps!
Be sure to let us know how it goes, thank you!
Jessica Thrasher
Message 27 of 29
s3304885
in reply to: jessica.t
No, have tried all those solutions, for gods sake what does it take to get
someone to call me and actually help!!!!!!*
Message 28 of 29
TravisNave
It takes a paid phone support contract with your local VAR. This is a peer
community.
Autodesk Forums:
Message 29 of 29
karl.hosking
Thanks for that registry edit tip. I too just found this problem with a new install of Inventor 2017.
After following all the steps under the below article, the problem still occurred;
 - https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
With the problem still occurring, a little more searching finally found this thread. I followed the regedit step, found the "L" zone regkey, backed it up & deleted it. Restarted the system, started Inventor, and now the licensing is working as expected and is no longer blank.
So to re-affirm, deleting the regkey (it's not an L, but a strange looking font) fixes a blank licensing screen;
Locate, backup & delete; HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\L
Administrator Productivity
