Installation & Licensing
Autdesk Education Master Suite 2013 issuing license
21 REPLIES 21
Message 1 of 22
badrinath
886 Views, 21 Replies
Single license file License Manager service as a single-server-model.
Checking license takes approximately 5 min in one site and some sites it takes 8 mins & issues the license
Pl. find the below detailed scenario
Server Specs: Windows server 2008 R2, 64 Bit OS,32 GB
Product is Education master suite 2013  licenses & the server configuration is through single server
The license server is in different sub net , but the connecting between the sever and the client is good , we tried pinging – this is fine and response is good
tried telnet - it is communicating to the ports 2080  & other recommended ports.
we have set the environmental variables FLEXLM_TIMEOUT to 100000000 & also ADSKFLEX_LICENSE_FILE pointing to the server
After all the above setting it takes 5 min in one site and some sites it takes 8 mins.
please adive any solution will be greatful to you.
21 REPLIES 21
Message 21 of 22
badrinath
in reply to: TravisNave
Hi thank you for all the suggestions.
I have tried all options , AutoCAD 2013 from the Education Master Suite takes time to open around 4-5 minutes , but other products in Master Suite takes around 1 minute.
pl advise.
Message 22 of 22
TravisNave
in reply to: badrinath
Right click the icon, choose enable/disable digital signature icons.  Uncheck the box.  Reboot.  See if that makes any difference.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
