Installation & Licensing
Autdesk Education Master Suite 2013 issuing license
21 REPLIES 21
Message 1 of 22
badrinath
880 Views, 21 Replies
Single license file License Manager service as a single-server-model.
Checking license takes approximately 5 min in one site and some sites it takes 8 mins & issues the license
Pl. find the below detailed scenario
Server Specs: Windows server 2008 R2, 64 Bit OS,32 GB
Product is Education master suite 2013  licenses & the server configuration is through single server
The license server is in different sub net , but the connecting between the sever and the client is good , we tried pinging – this is fine and response is good
tried telnet - it is communicating to the ports 2080  & other recommended ports.
we have set the environmental variables FLEXLM_TIMEOUT to 100000000 & also ADSKFLEX_LICENSE_FILE pointing to the server
After all the above setting it takes 5 min in one site and some sites it takes 8 mins.
please adive any solution will be greatful to you.
21 REPLIES 21
Message 2 of 22
TravisNave
in reply to: badrinath
Welcome to the Autodesk peer support forum!
Does it actually sit there and prompt that it is checking for the license?
Your timeout variable seems a little high, but ultimately shouldn't matter.
Autodesk Forums:
Message 3 of 22
badrinath
in reply to: TravisNave
thanks for your response , yes it load the software and then sits on for 5 min + given the messege checking license
after this it issues the license.
please advice
Message 4 of 22
TravisNave
And every product in the Suite does this or just one of the products?
Autodesk Forums:
Message 5 of 22
badrinath
every product does the same thing
Message 6 of 22
TravisNave
If you borrow a license, does it open immediately?
Autodesk Forums:
Message 7 of 22
badrinath
yes , it does open quickly when the license is borrowed
also is found out the below:
When I borrowed the license it works well for that windows user A , once we log-off A & log-on with the different user- B in the same desktop , it is again checking for license and works will only if you borrow being this user-B.
Is this how it works or anything can be done to borrow so it works for all the users with One borrow
Message 8 of 22
TravisNave
No, that is by design.  Borrow is dependent on the user.
Autodesk Forums:
Message 9 of 22
badrinath
thanks , pl advice on the license delay issue
waitiing for response
Message 10 of 22
TravisNave
Hmmm...  Is the Autodesk License Service started on the client before the application opens?  If not, try starting it manually then launch.
Autodesk Forums:
Message 11 of 22
badrinath
Sent from my iPad
Message 12 of 22
badrinath
Thanks , will try , pL advice the variable in client PC
Message 13 of 22
TravisNave
The variable should really not have to be set for more than one-million (1000000), which equals one second of delay.  I don't think having one-hundred million will cause any problems, but I've never set it that high before.  It's just a timeout to wait for the server to send the license response.
Autodesk Forums:
Message 14 of 22
badrinath
Pl let me know which service you r mentioning in the client
Message 15 of 22
TravisNave
The Flexnet Licensing Service in services.msc.  Or similarly named, I assume.  Typically it is set to manual and starts when the app starts.  You might have luck starting it first, then launching.  It's just a thought...
Autodesk Forums:
Message 16 of 22
badrinath
Will try & update , pl let me know if any more suggestion you have
Message 17 of 22
dgorsman
It *might* be looking for other license servers first if multiple servers are specified and the first one(s) checked doesn't have the required license or doesn't exist.  For example we've consolidated our licenses over the years and some of the old installs were pointing to license server names which didn't exist any more.  There's a host of different locations to specify the license server - env variable, registry, LIC files off the top of my head.
Message 18 of 22
TravisNave
in reply to: dgorsman
Very good point.  I would definitely check the LICPATH.LIC file (if exists) as well as the ADSKFLEX_LICENSE_FILE system environment variable and make sure all are accurate.  In fact, adding the variable might help.
Autodesk Forums:
Message 19 of 22
badrinath
Thank for your time , u r suggesting uninstall & reinstalling the client
Message 20 of 22
TravisNave
No.  Just changing the pathing to how the client looks to get the license file.
Autodesk Forums:
Administrator Productivity
