Installation & Licensing
Autcad 2014 license file does not work with Autcad 2012
16 REPLIES 16
Message 1 of 17
j.beavers
470 Views, 16 Replies
i have received a new license file (network ) for Autcad 2014 (mulitple seats), it works well with Acad 2014, but I am unable to get my Acad 2012 to obtain a valid license. I have searched for the cascadeinfo.cas file to remove it, but i could not find it anywhere on my computer.
16 REPLIES 16
Message 2 of 17
DarrenP
in reply to: j.beavers
does your license have a package statement in it?
run your license file through here to verify
www.licenseparser.com
DarrenP
Message 3 of 17
TravisNave
Darren is exactly right.  Basically, if your new 2014 license was generated while not under Subscription, then you won't be able to run previous versions.  If your Subscription has expired or lapsed, you might want to check on that.  If you renewed, maybe it hasn't posted yet.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 17
j.beavers
in reply to: TravisNave
we are currently under subscription and have not had a lapsed.
Message 5 of 17
TravisNave
As Darren said, check the license and make sure there is a PACKAGE.  The parser should show 2012 seats available if it is set up correctly.  So should your status enquiry in LMTOOLS.  Verify what you have and let us know.
Autodesk Forums:
Message 6 of 17
j.beavers
the package and LMTools shows seats from Acad 2011 to Acad 2014  - and it shows that we have two licenses
Message 7 of 17
TravisNave
What error are you getting when you launch 2012?
Autodesk Forums:
Message 8 of 17
j.beavers
our Acad 2012 license file works well and we have no poblem obtaining a license on diffrent machines.
Message 9 of 17
j.beavers
Error -5.412.0
Message 10 of 17
TravisNave
-5 definitely means it is not seeing the license.  Are the 2012 and 2014 both vanilla?  And you deleted the CascadeInfo.cas file already, right?
Autodesk Forums:
Message 11 of 17
j.beavers
what is vanilla? We have AutoCad14 Infrastruc Design Suite Prem and Acad Civil 3d 2012
Message 12 of 17
j.beavers
Message 13 of 17
j.beavers
Message 14 of 17
TravisNave
Okay thanks.  Civil 3D should cascade to IDS.  Did you delete the CascadeInfo.cas and did it get recreated?  Is there any errors in the debug.log file in LMTOOLS?
You can find the CascadeInfo.cas file here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13894457&linkID=9240617
It is in a hidden folder.
Autodesk Forums:
Message 15 of 17
DarrenP
for civil 3d 2012 install this hotfix
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17253046&linkID=9240698
DarrenP
Message 16 of 17
TravisNave
in reply to: DarrenP
How did I ask the version with this intent, then forget to mention the hotfix?  I am losing my touch...  Smiley Very Happy
Autodesk Forums:
Message 17 of 17
j.beavers
thanks, that worked.
Administrator Productivity
