i have received a new license file (network ) for Autcad 2014 (mulitple seats), it works well with Acad 2014, but I am unable to get my Acad 2012 to obtain a valid license. I have searched for the cascadeinfo.cas file to remove it, but i could not find it anywhere on my computer.
does your license have a package statement in it?
run your license file through here to verify
DarrenP
Darren is exactly right. Basically, if your new 2014 license was generated while not under Subscription, then you won't be able to run previous versions. If your Subscription has expired or lapsed, you might want to check on that. If you renewed, maybe it hasn't posted yet.
Good Luck!
As Darren said, check the license and make sure there is a PACKAGE. The parser should show 2012 seats available if it is set up correctly. So should your status enquiry in LMTOOLS. Verify what you have and let us know.
the package and LMTools shows seats from Acad 2011 to Acad 2014 - and it shows that we have two licenses
What error are you getting when you launch 2012?
-5 definitely means it is not seeing the license. Are the 2012 and 2014 both vanilla? And you deleted the CascadeInfo.cas file already, right?
what is vanilla? We have AutoCad14 Infrastruc Design Suite Prem and Acad Civil 3d 2012
Okay thanks. Civil 3D should cascade to IDS. Did you delete the CascadeInfo.cas and did it get recreated? Is there any errors in the debug.log file in LMTOOLS?
You can find the CascadeInfo.cas file here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13894457&linkID=9240617
It is in a hidden folder.
for civil 3d 2012 install this hotfix
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17253046&linkID=9240698
DarrenP
How did I ask the version with this intent, then forget to mention the hotfix? I am losing my touch...
