I failed to install autocad. I am not sure what is the cause. I would like to know how to solve it. Many Thanks. Below is the log.
PageOpen LaunchDialog
PageOpen LicenseDialog
PageOpen ProductInfoDialog
PageOpen ProductSelectionDialog2
PageOpen FullProgressDialog
Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\Autocad 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\joewey\AppData\Local\Temp\vcredist_x86_2010.log
2012/6/3:15:03:35 joewey JWSOO9821 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): E:\Autocad 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\joewey\AppData\Local\Temp\vcredist_x64_2010.log
2012/6/3:15:03:42 joewey JWSOO9821 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
Installing DirectX Runtime: E:\Autocad 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/3:15:04:44 joewey JWSOO9821 Install DirectX Runtime Succeeded
Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autocad 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
Install FaroSDK Succeeded
Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autocad 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
Install Autodesk Material Library 2013 Succeeded
Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autocad 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
Install Autodesk Material Library 2013 - Low Resolution Succeeded
Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="E:\Autocad 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autocad 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
Install Autodesk Content Service Succeeded
Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autocad 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
Install Autodesk Content Service Language Pack Succeeded
Installing AutoCAD® 2013: TRANSFORMS="E:\Autocad 2013\x64\en-us\acad\acad.mst;C:\Users\joewey\AppData\Local\Temp\_AI6CB1.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autocad 2013\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
Install AutoCAD® 2013 Failed Installation aborted, Result=1603
Rollback Autodesk Content Service Language Pack Succeeded
Rollback Autodesk Content Service Succeeded
Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
Rollback Autodesk Material Library 2013 Succeeded
Rollback FaroSDK Succeeded
Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
PageOpen InstallCompleteDialog
=== Setup ended ===
=== Setup started on JWSOO9821 by joewey ===
Launch
=== Setup ended ===
Launch
An instance of setup is already running. Only one instance of setup can run at a time.2012/6/3:15:28:26 joewey JWSOO9821 === Setup ended ===
Launch
2012/6/3:15:16:42 joewey JWSOO9821 Install DirectX Runtime Succeeded
Installing AutoCAD® 2013: TRANSFORMS="E:\Autocad 2013\x64\en-us\acad\acad.mst;C:\Users\joewey\AppData\Local\Temp\_AI62B3.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autocad 2013\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
=== Setup ended ===
Launch
=== Setup ended ===
Launch
2012/6/3:17:31:15 joewey JWSOO9821 Install DirectX Runtime Succeeded
Installing AutoCAD® 2013: TRANSFORMS="E:\Autocad 2013\x64\en-us\acad\acad.mst;C:\Users\joewey\AppData\Local\Temp\_AI7687.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autocad 2013\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
Try copying the contents of the install media from your E:\ drive and put them all in a folder on your C:\ drive. Then install it from there locally. You might have better luck right-clicking setup.exe and Run as Administrator. As always, make sure anti-virus is disabled and UAC is off.
