Hello, everyone. I have been having some issues installing 3ds Max and I am coming to you with the hopes of resolving them. The version I have been trying to install is 3ds Max 2014 student version (and I even tried the 2010 version, as that was the version I was trained in). I got the installer via download from the virtual agent. I've been looking around trying different suggested solutions but nothing is working. This computer has been reformatted, but before the reformatting, Max 2014 installed without a problem. I will paste the error log I get from installer and I will attach the %TEMP% error log to this post. Thank you in advance!
2014/7/16:22:26:06 Admin JAMESPC2014 === Setup started on JAMESPC2014 by Admin ===
2014/7/16:22:26:06 Admin JAMESPC2014 Path_Length: 151
2014/7/16:22:26:06 Admin JAMESPC2014 Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm
2014/7/16:22:26:06 Admin JAMESPC2014 Launch
2014/7/16:22:26:06 Admin JAMESPC2014 CommandLine
2014/7/16:22:26:06 Admin JAMESPC2014 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI5CC3.tmp
2014/7/16:22:26:09 Admin JAMESPC2014 === Setup ended ===
2014/7/16:22:26:07 Admin JAMESPC2014 === Setup started on JAMESPC2014 by Admin ===
2014/7/16:22:26:07 Admin JAMESPC2014 Path_Length: 151
2014/7/16:22:26:07 Admin JAMESPC2014 Current Directory C:\Users\Admin\AppData\Local\Temp\_AI5CC3.tmp
2014/7/16:22:26:07 Admin JAMESPC2014 Launch
2014/7/16:22:26:09 Admin JAMESPC2014 PageOpen LaunchDialog
2014/7/16:22:40:04 Admin JAMESPC2014 PageOpen LicenseDialog
2014/7/16:22:40:07 Admin JAMESPC2014 PageOpen ProductInfoDialog
2014/7/16:22:40:49 Admin JAMESPC2014 PageOpen ProductSelectionDialog2
2014/7/16:22:40:54 Admin JAMESPC2014 PageOpen FullProgressDialog
2014/7/16:22:40:55 Admin JAMESPC2014 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/7/16:22:40:58 Admin JAMESPC2014 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
