How to fix this message? This message is always appearing on my screen and causing my AutoCad to crash.
Please Help!
What version of AutoCAD are you running and when does it appear? If it is drawing related, please be sure it was not modified and saved in a later version or a vertical product.
I'm using AutoCad 2005. If the drawing I'm trying to open was saved in earlier version, what do I need to do to on my autocad 2005 version so this message will not appear?
I'm more wondering if your drawing was saved in a later version or a vertical. Can you attach your drawing here by chance?
You are right, there's a message that always pop up whenever I open a drawing, actually only happens on certain drawings, The drawing was saved in newer version and some tools/commands will not work on the version I am using or something like that. Help?
That's what I had figured. What you will need to do in that case is open the drawings in 2007 or later and resave the drawing back down to 2004 format.
have saved drawing down to 2004 version, but still crashes when trying to "copy / paste". Is there a "hotfix" that can be downloaded?
these are the hot fixes for autocad 2005: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618#section8
don't know if any will fix your problem
DarrenP
autocad lt hotfixes: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240818
DarrenP
what are you trying to install?
DarrenP
our regular IT man has been shown the door and I was asked by my boss to install a "hotfix" to resolve the problem we are having with ARX_ERROR....
can you walk me thru the steps?
i am assuming your trying to install the service pack?
DarrenP
i wouldn't do anything if you don't know what are you are installing
DarrenP
do you know the exact hotfix your trying to install from the link I provided?
DarrenP
