Installation & Licensing
ARSA 2012 shows a splash screen and closes
1 REPLY 1
Priitl220
234 Views, 1 Reply
After fresh installation Robot Strcutural Analysis 2012 pro shows a splash screen on start and closes.
Win 7 Pro 64 bit.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Tags (1)
1 REPLY 1
david.lau
in reply to: Priitl220
It could be a pit file problem:
http://forums.autodesk.com/t5/Installation-Licensing/What-is-the-Productinformation-pit-file-amp/m-p...
Basically, I would copy the .pit file from a working system to a non-working system.
You can also check out this solution:
http://usa.autodesk.com/getdoc/id=TS15176093
The "cascadeinfo.cas" file issue should be resolved in all products in 2012 or higher.
David Lau
Administrator Productivity
