Installation & Licensing
Architecture 2011 Language Packs error 1603
0 REPLIES 0
Message 1 of 1
bharch
233 Views, 0 Replies
Can't install ACA2011 on Win7Pro 64bit with full admin rights. It fails at the Language Packs installation portion and rolls back.
Here is the log info:
2013/4/18:12:37:42 NewPC DELLPC === Setup started on DELLPC by NewPC === 2013/4/18:12:38:04 NewPC DELLPC === Setup ended ===
2013/4/18:12:37:55 NewPC DELLPC === Setup started on DELLPC by NewPC === 2013/4/18:12:40:21 NewPC DELLPC Install DirectX 9.0 Runtime Succeeded  2013/4/18:12:42:40 NewPC DELLPC Install DirectX 9.0 Runtime Succeeded  2013/4/18:12:42:49 NewPC DELLPC Install FARO LS 1.1.406.58 Succeeded  2013/4/18:12:43:08 NewPC DELLPC Install Autodesk Material Library 2011 Succeeded  2013/4/18:12:43:39 NewPC DELLPC Install Autodesk Material Library 2011 Base Image library Succeeded  2013/4/18:12:46:06 NewPC DELLPC Install AutoCAD Architecture 2011 Succeeded  2013/4/18:12:52:10 NewPC DELLPC Install AutoCAD Architecture 2011 Language Pack Failed Installation aborted, Result=1603 2013/4/18:12:52:28 NewPC DELLPC Rollback AutoCAD Architecture 2011 Succeeded  2013/4/18:12:52:37 NewPC DELLPC Rollback Autodesk Material Library 2011 Base Image library Succeeded  2013/4/18:12:52:43 NewPC DELLPC Rollback Autodesk Material Library 2011 Succeeded  2013/4/18:12:52:44 NewPC DELLPC Rollback FARO LS 1.1.406.58 Succeeded  2013/4/18:12:52:45 NewPC DELLPC Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619 2013/4/18:12:52:55 NewPC DELLPC === Setup ended ===
2013/4/18:13:07:32 NewPC DELLPC === Setup started on DELLPC by NewPC === 2013/4/18:13:09:12 NewPC DELLPC === Setup ended ===
2013/4/18:13:07:22 NewPC DELLPC === Setup started on DELLPC by NewPC === 2013/4/18:13:09:12 NewPC DELLPC === Setup ended ===
How do I fix it?
0 REPLIES 0
Administrator Productivity
