I had this problem with ArcGIS a while ago and again today, installing a Lieca Geosystems FlexLM license. Here's what I wrote for Leica tech but I did the same for ArcGIS (9.3 though 10.2).
After installing CLM on our license server, AutoCAD license became inaccessible. This is due to a conflict over server ports through which the Flexera Software LMTOOLS listens for license pings from clients and serves out licenses. To resolve the conflict, administrator must override default port of 27000. To do this:
SERVER this_host ANY
VENDOR LGS PORT=27010
USE_SERVER
FEATURE JumpStartFeature LGS 1.0 permanent 1 SIGN="[encrypted license key]”
Revised:
SERVER [hostname] ANY 27005
VENDOR LGS PORT=27006
USE_SERVER
Note that ArcGIS, AutoCAD and Leica all use the FlexLM license manager, so port numbers may have to be changed for other services. The content of the AutoCAD license file is different from ArcGIS and Leica and does not allow override of the Port=27000 setting. Either that, or BECAUSE Leica and ArcGIS use third party LM interfaces atop the Flexera LMTOOLS, LMTOOLS cannot automatically allocate non-conflicting ports. In any case, the workaround above works.
--ML
Matthew Lawson, PhD/AICP/PP
Principal Planner
Mercer County Planning Division
640 South Broad St., CAB 411
Trenton, NJ 08611
v 609-989-6551
f 609-989-6546
That's a pretty good solution. However, If you upgrade and combine the license managers into one location, using one latest lmgrd.exe and add in all the vendor daemon files (adskflex.exe) then the ports will be handled automagically.
For the best method to properly combine your license files, please read my entire thread here and choose the method that best fits your needs:
http://forums.autodesk.com/t5/Installation-Licensing/Combining-License-Files-for-Subscription-and-No...
Thanks!
Hello. I have certainly seen this. You need to make sure the Autodesk service is using the Autodesk 11.12 Kernel and no other service is trying to use this exe. Also, open your License file and at the top, after your MAC address, put a space and then type 27005 and save the file. Stop the service and restart.
This will bind the license to port 27005 and usually alleviates a port service conflict with arcGIS
Thank you for taking part in our community!
