We're running AutoDesk Inventor Professional 2012 on Windows 7 Enterprise 64B.
ApplicatioOptions.xml does not work if:
The only way to start with the predefined settings is bij import them (Tools > Appliocation Options > Import)
So the question is: Why does 1 and 2 not work for us?
Best regards,
Solved by pierre.masson. Go to Solution.
Hello Adenm.
We know that not all options are imported when using Process 1 and 2. Our developers are working on it to solve this issue.
In the meantime, two options :
Dear Pierre,
Best wishes for 2012 and thank you for the response, this helps a lot!
regards,
adenm
Hi Pierrre,
One more question;
This is a HKCU setting. Do you have an option to set it to all Users or Local machine?
Marco
Hi Adenm
Unfortunately the settings need to be set in HKCU.
If you need to deploy this for multiple users on one machine, you can use these Microsoft solutions :
Warning!
The following steps involve change in system registry. Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft provides a wealth of critical information that you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com/support.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined for your operating system in the Microsoft Knowledge Base and in the related solution, TS66513.
