I have a student license, and tried several times installing AutoCAD 2014 on my Windows 8.1 machine. Here is the error log:
2014/4/3:17:50:36 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:17:50:36 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:17:50:36 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/3:17:50:36 knoetzefamily HANNES_HOME Launch
2014/4/3:17:50:36 knoetzefamily HANNES_HOME CommandLine
2014/4/3:17:50:36 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AIBA2B.tmp
2014/4/3:17:50:56 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/3:17:50:43 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:17:50:43 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:17:50:43 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AIBA2B.tmp
2014/4/3:17:50:43 knoetzefamily HANNES_HOME Launch
2014/4/3:17:50:45 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AIBA2B.tmp\Setup\AcSetup.dll
2014/4/3:17:50:45 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:17:50:54 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/3:17:51:08 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:17:51:22 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/3:17:54:15 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/3:17:54:35 knoetzefamily HANNES_HOME PageOpen FullProgressDialog
2014/4/3:17:54:36 knoetzefamily HANNES_HOME Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/4/3:17:57:57 knoetzefamily HANNES_HOME Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
2014/4/3:17:57:59 knoetzefamily HANNES_HOME PageOpen InstallCompleteDialog
2014/4/3:18:02:58 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/3:18:09:05 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:18:09:05 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:18:09:05 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/3:18:09:05 knoetzefamily HANNES_HOME Launch
2014/4/3:18:09:05 knoetzefamily HANNES_HOME CommandLine
2014/4/3:18:09:05 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AIA902.tmp
2014/4/3:18:09:23 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/3:18:09:11 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:18:09:11 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:18:09:11 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AIA902.tmp
2014/4/3:18:09:11 knoetzefamily HANNES_HOME Launch
2014/4/3:18:09:13 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AIA902.tmp\Setup\AcSetup.dll
2014/4/3:18:09:13 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:18:09:22 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/3:18:11:16 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:18:11:27 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/3:18:14:22 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:18:14:25 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/3:18:16:07 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:18:16:08 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/3:18:16:11 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:18:16:15 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/3:18:16:40 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/3:18:21:39 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:18:21:39 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:18:21:39 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/3:18:21:39 knoetzefamily HANNES_HOME Launch
2014/4/3:18:21:39 knoetzefamily HANNES_HOME CommandLine
2014/4/3:18:21:39 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI2A61.tmp
2014/4/3:18:21:57 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/3:18:21:44 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:18:21:44 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:18:21:44 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI2A61.tmp
2014/4/3:18:21:44 knoetzefamily HANNES_HOME Launch
2014/4/3:18:21:47 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AI2A61.tmp\Setup\AcSetup.dll
2014/4/3:18:21:47 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:18:21:56 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/3:18:22:58 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:18:23:17 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/3:18:23:50 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/3:18:32:40 knoetzefamily HANNES_HOME PageOpen FullProgressDialog
2014/4/3:18:32:41 knoetzefamily HANNES_HOME Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/4/3:18:55:25 knoetzefamily HANNES_HOME Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
2014/4/3:19:27:19 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:19:27:19 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:19:27:19 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/3:19:27:19 knoetzefamily HANNES_HOME Launch
2014/4/3:19:27:19 knoetzefamily HANNES_HOME CommandLine
2014/4/3:19:27:19 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI4690.tmp
2014/4/3:19:27:36 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/3:19:27:24 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:19:27:24 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:19:27:24 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI4690.tmp
2014/4/3:19:27:24 knoetzefamily HANNES_HOME Launch
2014/4/3:19:27:26 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AI4690.tmp\Setup\AcSetup.dll
2014/4/3:19:27:26 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:19:27:35 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/3:19:27:56 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:19:28:10 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/3:19:28:40 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/3:19:28:46 knoetzefamily HANNES_HOME PageOpen FullProgressDialog
2014/4/3:19:28:47 knoetzefamily HANNES_HOME Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/4/3:19:30:16 knoetzefamily HANNES_HOME Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
2014/4/3:20:23:51 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:20:23:51 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:20:23:51 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/3:20:23:51 knoetzefamily HANNES_HOME Launch
2014/4/3:20:23:51 knoetzefamily HANNES_HOME CommandLine
2014/4/3:20:23:51 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AIB30.tmp
2014/4/3:20:24:06 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/3:20:23:56 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/3:20:23:56 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/3:20:23:56 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AIB30.tmp
2014/4/3:20:23:56 knoetzefamily HANNES_HOME Launch
2014/4/3:20:23:58 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AIB30.tmp\Setup\AcSetup.dll
2014/4/3:20:23:58 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/3:20:24:06 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/3:20:24:16 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:20:24:16 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/3:20:24:26 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:20:24:26 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/3:20:24:30 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/3:20:24:42 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/3:20:26:37 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/3:20:26:46 knoetzefamily HANNES_HOME PageOpen FullProgressDialog
2014/4/3:20:26:46 knoetzefamily HANNES_HOME Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/4/3:20:28:05 knoetzefamily HANNES_HOME Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
2014/4/3:20:28:08 knoetzefamily HANNES_HOME PageOpen InstallCompleteDialog
2014/4/3:22:00:05 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/4:17:17:03 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/4:17:17:03 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/4:17:17:03 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/4:17:17:03 knoetzefamily HANNES_HOME Launch
2014/4/4:17:17:03 knoetzefamily HANNES_HOME CommandLine
2014/4/4:17:17:03 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI605A.tmp
2014/4/4:17:17:24 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/4:17:17:09 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/4:17:17:09 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/4:17:17:09 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI605A.tmp
2014/4/4:17:17:09 knoetzefamily HANNES_HOME Launch
2014/4/4:17:17:13 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AI605A.tmp\Setup\AcSetup.dll
2014/4/4:17:17:13 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/4:17:17:22 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/4:17:17:27 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/4:17:17:40 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/4:17:18:52 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/4:17:19:13 knoetzefamily HANNES_HOME PageOpen FullProgressDialog
2014/4/4:17:19:13 knoetzefamily HANNES_HOME Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/4/4:17:20:05 knoetzefamily HANNES_HOME Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
2014/4/4:17:20:07 knoetzefamily HANNES_HOME PageOpen InstallCompleteDialog
2014/4/4:17:22:53 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/4:18:04:57 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/4:18:04:57 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/4:18:04:57 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/4:18:04:57 knoetzefamily HANNES_HOME Launch
2014/4/4:18:04:57 knoetzefamily HANNES_HOME CommandLine
2014/4/4:18:04:57 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI3B86.tmp
2014/4/4:18:05:17 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/4:18:05:04 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/4:18:05:04 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/4:18:05:04 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI3B86.tmp
2014/4/4:18:05:04 knoetzefamily HANNES_HOME Launch
2014/4/4:18:05:07 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AI3B86.tmp\Setup\AcSetup.dll
2014/4/4:18:05:07 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/4:18:05:15 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/4:18:05:19 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/4:18:05:28 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/4:18:05:48 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/4:18:06:06 knoetzefamily HANNES_HOME PageOpen FullProgressDialog
2014/4/4:18:06:06 knoetzefamily HANNES_HOME Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/4/4:18:07:33 knoetzefamily HANNES_HOME Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
2014/4/4:18:07:36 knoetzefamily HANNES_HOME PageOpen InstallCompleteDialog
2014/4/4:18:08:13 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/4:20:06:34 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/4:20:06:34 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/4:20:06:34 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/4:20:06:34 knoetzefamily HANNES_HOME Launch
2014/4/4:20:06:34 knoetzefamily HANNES_HOME CommandLine
2014/4/4:20:06:34 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI130A.tmp
2014/4/4:20:07:01 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/4:20:06:38 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/4:20:06:38 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/4:20:06:38 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI130A.tmp
2014/4/4:20:06:38 knoetzefamily HANNES_HOME Launch
2014/4/4:20:06:42 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AI130A.tmp\Setup\AcSetup.dll
2014/4/4:20:06:42 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/4:20:06:58 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/4:20:07:00 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/4:20:07:15 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/4:20:08:30 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/4:20:08:40 knoetzefamily HANNES_HOME PageOpen FullProgressDialog
2014/4/4:20:08:41 knoetzefamily HANNES_HOME Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/4/4:20:10:37 knoetzefamily HANNES_HOME Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
2014/4/4:20:10:38 knoetzefamily HANNES_HOME PageOpen InstallCompleteDialog
2014/4/4:20:13:24 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/5:18:49:11 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/5:18:49:11 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/5:18:49:11 knoetzefamily HANNES_HOME Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm
2014/4/5:18:49:11 knoetzefamily HANNES_HOME Launch
2014/4/5:18:49:11 knoetzefamily HANNES_HOME CommandLine
2014/4/5:18:49:11 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI9539.tmp
2014/4/5:18:49:32 knoetzefamily HANNES_HOME === Setup ended ===
2014/4/5:18:49:17 knoetzefamily HANNES_HOME === Setup started on HANNES_HOME by knoetzefamily ===
2014/4/5:18:49:17 knoetzefamily HANNES_HOME Path_Length: 155
2014/4/5:18:49:17 knoetzefamily HANNES_HOME Current Directory C:\Users\KNOETZ~1\AppData\Local\Temp\_AI9539.tmp
2014/4/5:18:49:17 knoetzefamily HANNES_HOME Launch
2014/4/5:18:49:21 knoetzefamily HANNES_HOME Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\KNOETZ~1\AppData\Local\Temp\_AI9539.tmp\Setup\AcSetup.dll
2014/4/5:18:49:21 knoetzefamily HANNES_HOME Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/4/5:18:49:32 knoetzefamily HANNES_HOME PageOpen LaunchDialog
2014/4/5:18:49:36 knoetzefamily HANNES_HOME PageOpen LicenseDialog
2014/4/5:18:49:50 knoetzefamily HANNES_HOME PageOpen ProductInfoDialog
2014/4/5:18:51:49 knoetzefamily HANNES_HOME PageOpen ProductSelectionDialog2
2014/4/5:19:01:14 knoetzefamily HANNES_HOME PageOpen FullProgressDialog
2014/4/5:19:01:14 knoetzefamily HANNES_HOME Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_32bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/4/5:19:11:52 knoetzefamily HANNES_HOME Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
I have tried to remove the .NET Framework v4.5 from my machine using the .NET Framework clean up utility, but according to Microsoft this can not be done because it is part of the OS.
What can I do?
Thank you,
Hannes.
