Ysbrand -
If you've already got you license for the SAMreport lite you're doing pretty well. I
can't get the globetrotter web page to work??
Anyway -
Create a file called adskflex.opt in the same location as the autodesk license file that
you received (not the samlite license file, the autodesk one). Open this file with your
favorite text editor (notepad always works for me) and put one line in it. Something like
REPORTLOG +C:\Report.log
should work. This tells the flexlm service to create a report log called report.log at
the root of your C drive. Now stop and start the FlexLM service and check the debug.log.
Make sure that it says something like
Using Options File: "C:\Program Files\Autodesk License Manager\License\adskflex.opt"
and
Report Log Started (C:\Report.log).
Now run the samreport but point to c:\report.log
hth
jason martin
frankfurt-short-bruza
"Y. Haagsma" wrote in message
news:F14EE566B79CEAD096C57B297D22F7C3@in.WebX.maYIadrTaRb...
> Thanks for answering my question but i don't understand which settings i
> must change.
> I have just installed for the first time an NLS-server for 8 licences for
> ACAD2002.
> I received the license file from autodesk and the FLEXlm server V7.1f is
> running.
> (by configuring a service and i set the log pad, licence pad)
> This working O.K.
> Then i asked for the license file for the SAMreport program and i installed
> it.
> When i start my LMtools, the service / license file -tab and configuration
> using license file-toggle button selected displays the
> c:/gsi/samreport/machineid/license/licen.dat as license file
> I've searched through the help files from FLEXlm and i find the same story
> as you send me as below.
> Because this is the first time i set up NLS, i don't know everything in
> detail.
> But could you help me setting up the SAMreport program and tell me excectly
> what to add, remove or change in the correct files.
> Thanks a lot
> Ysbrand Haagsma
> PS I''ve scanned the discussion group messages and i didn't find the string
> SAMREPOrt. Am i the only one who doesn't understand the installation of the
> SAM program ?
> PS I think the discussion groups work very good !!
> Ysbrand Haagsma
> The Netherlands
