Installation & Licensing
Another licensing issue
5 REPLIES 5
VampX
818 Views, 5 Replies
Hi there,
Ill keep it brief.
The Situation:
Network license run on linux server
Maya 2010 client side Windows XP
Starting up Maya 2010 error received when trying to find network license:
A valid license could not be obtained by the network license manager
Error [-15.570.10035]
Then a further screen pops up with:
A license related problem has occurred.
[-12]
Verified the license manager is running.
No other errors received from any other machines, just this one.
I am very new to this company and very new to the AutoDesk Maya environment. Considering there was absolutely no documentation around when I came on board I think I'm doing very well, setting aside this issue.
All help greatly appreciated.
V
5 REPLIES 5
TravisNave
in reply to: VampX
-12 Invalid returned data from license server system.
Did you follow the Autodesk directions on setting up the NLM on a Linux server?
Autodesk Forums:
VampX
in reply to: VampX
Unfortunately I wasn't the one who set it up. I shall have a look at it again though. Anything I need to be aware of? Funny that only one client is receiving the error whereas the others aren't. Network license is for 10.
phcaduser
in reply to: VampX
hi travis, what if i bought an autocad software in singapore and it was not used, can i legally use it in my office in the Philippines?
ssadat
in reply to: VampX
ping the server from client machine.check it is pinging?and when u run the autocad on client machine when it asked the server name enter the ip address not the server name and then try.
VampX
in reply to: VampX
Ok,
I've resolved this issue. Turns out the server daemon was actually listening on port 7112 and *not* 7111 - as the client is configured to send requests on.
Once I changed that it all loaded and didn't complain once. However, I am still in the dark as to how the others with exactly the same .dat file can be obtaining licenses.
Hmm.
I should have stated it was a multi license server machine too.
Administrator Productivity
