Installation & Licensing
an internet connection is required to install a windows component?
5 REPLIES 5
ssc.james
35714 Views, 5 Replies
I think my installer is broken for softimage... I am trying to run trial but it says an internet connection is required to install a windows component. I have internet on CLEARLY and have disconnected and reconnected etc. but still dosen't work.
This also happens on other installers aswell. Is it .NET mainframe?
5 REPLIES 5
TravisNave
in reply to: ssc.james
Thanks for using the forums.  Can you post any screencaps or log files?
Autodesk Forums:
david.lau
in reply to: TravisNave
Use a Browser Download of the software.  Please review step 1 in this blog post:
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
If necessary, you can order media as necessary.
David Lau
AnkushVed
Try this link:
http://docs.autodesk.com/ETOCOMP/2014/ENU/files/GUID-C6B86709-D6ED-437C-ACC3-E4C099531187.htm
Ankush Ved
Product Manager, Autodesk Licensing
e164970
in reply to: AnkushVed
I'm trying to install 3dsMax 2014 to my win8 pc. However it keeps giving me the folllowing error:
An Internet connection is required to install a Windows component. Please connect and re-launch the installer.
I've read some of the earlier messages however could not find a solution. I disabled my virus protection program, enabled windows update but still no change..
Can someone help please?
Thanks a lot!
jpassalacqua
in reply to: e164970
make sure you have .net 3.5 enabled.
we have WSUS server and for some reason it doesnt enable when the policy gets applied, so we have to run:
Dism /online /enable-feature /featurename:NetFX3 /All /Source:
 where source is a network share.
after that, it installed fine.
Administrator Productivity
