Installation & Licensing
Alias - "You do not have a user_data directory"
3 REPLIES 3
7993 Views, 3 Replies
why dosen't work ... alias?
I have a serial number....but dosen't work ㅜ_______________________________________________ㅜ
please help me~!!
3 REPLIES 3
david.lau
Make sure that you have set your permissions to 'Everyone" to the followign folder.
C:\Users\YOUR-USER-NAME\Documents\Autodesk
or
http://forums.autodesk.com/autodesk/attachments/autodesk/24/49646/1/everyone.zip
Alias will create files/folders here and should be created upon first launch.
C:\Users\YOUR-USER-NAME\Documents\Autodesk\Alias\user_data
The ALIAS_WORKENV overrides this location from the default to a custom path.  Again, you need to make sure that you have permissions to that path.
http://usa.autodesk.com/getdoc/id=TS1089989
Personally, I would just delete the ALIAS_WORKENV as a test if you have set it.
David Lau
in reply to: david.lau
Great! Works in Mac too
I tried above instruction before and it worked on my computure...
BUT, I've recently re-installed my computure and all the programs..
this time, Alias is not working as the same reasone (you do not have a user_data directory:)
Does anyone knows other solution??
or shall I use window 7 instead?
my computuer:
window 8 64bit
intel i7_4700MQ
8GB DDR3
750GB 5400rpm SATA
Thanks!!
Administrator Productivity
