Installation & Licensing
New Member
0 Kudos
Post 1 of 2
Alias 2014 wont start
252 Views, 1 Replies
08-11-2013 11:42 PM
Hi All,
I have just downloaded a Mentor licensed copy of Alias Automaotive 2014.  Installation appeared succesful until I came to open Alias for the first time.
- A small pop-up states "Please wait while your license is verified"
- The start-up window goes grey as another window informs me: "Autodesk component has stopped working"
Under problem details the following information is given:
- Problem Event Name:      APPCRASH
- Application Name:           LMU.exe
- Application Version:       7.0.51.0
- Application Timestamp:   50f8df72
- Fault Module Name:        mshtml.dll
- Fault Module Version:    10.0.9200.16635
Can anyone help me resolve this issue - or should I simply uninstall and start again?
Best regards
Mark
*Expert Elite*
894 Kudos
Post 2 of 2
Re: Alias 2014 wont start
08-12-2013 07:48 AM in reply to: Mark_Pearson
Welcome to the community.
I have seen this happen if IE10 is installed.  You *might* try uninstalling it if you can and see if that works.
Also, it could be the 2014 Activation crash.  You might check that out to see if it is applicable to your problem.
Good Luck!
Post to the Community
New Post
