We have an Algo Simulation network license. We have added this license to our license server via LMtools. LMTools shows that there is a free license available to use for 2011.
During the client install I selected the network License option and have selected the single license server.
When Algor starts it asks to select either a license file or a license system. i select the license system and put in the server name of the license server. I click next and it finds the server and lets me click finish. However after clicking finish it takes me back to selecting either the license file or license system. I have tried putting in a bogus server name and it does come back to say it fails to find that server. So i know I must have the server name correct.
The problem is it continually loops through this initial setup screen(s) and never starts the application.
What am I doing wrong?
Trever Dennis
I suspect a mismatch in the feature code being requested from server.
Please create a system environmental variable “FLEXLM_DIAGNOSTICS” with value as 3. This should show you the exact feature code client is requesting the server (normally a pop-up screen).
You can see the list of codes here.
http://usa.autodesk.com/getdoc/id=TS15224763
If the licensing is being denied, it should be shown in the license server log.
if this doesn’t help you can also look this solution about corrupt cascadeinfo.cas
http://usa.autodesk.com/getdoc/id=TS13894457
