Installation & Licensing
Algor Simulation 2011 Activation Failure
2 REPLIES 2
832 Views, 2 Replies
Activiation issues..
Upgraded to Algor 2011 from 23.1 and used trial licensing for awhile.
Received a new license for FlexLM to use.  Set it up and appeared to run according to diagnostics.
Started Algor and program displayed activation screen.
Started the activation process using the online option.
Received error code 123 with a failure notification.
Algor fails to start.
Any suggestions?
-Sean
2 REPLIES 2
TravisNave
Trial versions are installed as stand-alone license types.  What you need to do is uninstall and then reinstall your product as a network seat, pointing to your FlexLM server.  You cannot activate a network license serial number on a stand-alone install.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Yes it turns out i missed the Configure button during the setup.  The configure button takes you through the license setup.
It was quite time consuming to go back through the installation because ot he miss.  Tech support walked me through and it works now.
Sean
Administrator Productivity
