Instead of setting LM_LICENSE_FILE use ADSKFLEX_LICENSE_FILE as it is read
in higher priority. The syntax of the variable is the same. That said, I
do not think this is what your problem is.
Are you running any internet security/firewall software on that workstation?
If so, make sure that TCP ports 27000 - 27009 plus 2080 are enabled.
Jerry Milana,
Autodesk Consulting
"Lars S" wrote in message
news:MPG.1acd5601a12e732a989703@discussion.autodesk.com...
> Hi, I meet a strange problem by one of our customers
> They have FLEXlm (v7.1f) with 5 licenses for AIS 6
> On one of the client PC's, when we try to start AIS 6 NLS up, we get the
License Finder dialog
> box every time. When we type in server host name/ IP-adress, the dialog
box returns that the
> server was found and then following error comes:
> Error [1.5 - 57], where the license couldn't start up.
> I was not able to find any answer here in this forum as well as on
Autodesk product support.
> From the same client PC, we can easily ping the server, both on host name
and IP-adress.
> Further more, when LMTOOLS is started from the client PC, it recognizes
the the pool of
> licenses.
> As a test the environment variable LM_LICENSE_FILE was set to @server,
still without luck.
> Even a total un-install with registry cleaning followed by a re-install
wouldn't help, again
> the Error [1.5 - 57] came up.
> Her collegues who also uses AIS 6 NLS start up normally without any
problems.
> Does anyone have a clue about that?
> Best regards
> Lars
