Installation & Licensing
New Member
samuel.burger
Message 1 of 2 (295 Views)
After Sil.Install Moldflow Communicator 2013 byDeployment Win7Profx86 didn't run
295 Views, 1 Replies
09-24-2012 11:24 AM
I created a Deployment with Autodesk Moldflow Communicator 2013 on Win7 64Bit Version I had no problems to start after the Installation, I create a new Deployment x86 on XP Professional x86 I had also no problem, but on win7 Professional x86 I can't run the software
after Silent Installation from the deployment...I always get a License Error from Moldflow Insight, but Insight is not installed on this machine, if i make an uninstall and install communicator 2013 manually I can run the program...
I compared the two installation there is one xml File Autodesk\Simulation Moldflow Communicator 2013\bin\Support\infocenter.xml which is a bit different and in Registry [HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Moldflow Communicator\2013] The Location is on manually Installation C:\\Program Files and on silent by Deployment
C:\\Programme though in the configuration.ini from the deployment location is %ProgramFiles%...
I tried to correct this few settings after the silent installation but when I run communicator I get allways the License Error from Insight I've attached the error screenprint.
Did someone duplicate this problem?
Can somebody help me with this problem?
Thanks in advance
Samuel
Product Support
molog2
Message 2 of 2 (262 Views)
Re: After Sil.Install Moldflow Communicator 2013 byDeployment Win7Profx86 didn't
09-26-2012 07:00 AM in reply to: samuel.burger
Working on it. May need to analyse license file and other system specific data. Will post the solution once I get it.
Giancarlo Molo
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
