I was having trouble with maya so I tried to uninstall, the standard uninstaller would not work so I went about removing it myself !
I got rid of files from the regedit,appdata,programfiles ect
Why won't the installer install maya for me now ? When I ran it again It reinstalled all the components;
mental ray renderer
Match Mover
Composite
Direct Connect
Now when I run the installer the only Sub-Component it has checked to download is backburner.
What should I do !
Note: When opening the Uninstaller I can now see Maya and the components , when trying to uninstall them they all go bar
Maya
Composite
Direct Connect
Post any installation log of the failure.
2014/4/9:21:20:35 Charlie CHARLIE_PC === Setup started on CHARLIE_PC by Charlie ===
2014/4/9:21:20:35 Charlie CHARLIE_PC Path_Length: 151
2014/4/9:21:20:35 Charlie CHARLIE_PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/9:21:20:35 Charlie CHARLIE_PC Launch
2014/4/9:21:20:35 Charlie CHARLIE_PC CommandLine
2014/4/9:21:20:35 Charlie CHARLIE_PC Current Directory C:\Users\Charlie\AppData\Local\Temp\_AI88CF.tmp
2014/4/9:21:20:44 Charlie CHARLIE_PC === Setup ended ===
2014/4/9:21:20:38 Charlie CHARLIE_PC === Setup started on CHARLIE_PC by Charlie ===
2014/4/9:21:20:38 Charlie CHARLIE_PC Path_Length: 151
2014/4/9:21:20:38 Charlie CHARLIE_PC Current Directory C:\Users\Charlie\AppData\Local\Temp\_AI88CF.tmp
2014/4/9:21:20:38 Charlie CHARLIE_PC Launch
2014/4/9:21:20:45 Charlie CHARLIE_PC PageOpen LaunchDialog
2014/4/9:21:20:56 Charlie CHARLIE_PC PageOpen ProductInfoDialog
2014/4/9:21:22:16 Charlie CHARLIE_PC PageOpen ProductSelectionDialog2
2014/4/9:21:22:20 Charlie CHARLIE_PC PageOpen FullProgressDialog
2014/4/9:21:22:20 Charlie CHARLIE_PC Installing mental ray® renderer for Autodesk® Maya® 2014: INSTALLDIR="C:\Program Files\Autodesk\mentalrayForMaya2014\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE={44FFD99B-4877-4732-AA33-2FD3D7B622D2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2014_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:21:22:36 Charlie CHARLIE_PC Install mental ray® renderer for Autodesk® Maya® 2014 Succeeded
2014/4/9:21:22:36 Charlie CHARLIE_PC Installing Autodesk® MatchMover™ 2014: INSTALLDIR="C:\Program Files\Autodesk\MatchMover2014\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE={44FFD99B-4877-4732-AA33-2FD3D7B622D2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2014_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:21:23:05 Charlie CHARLIE_PC Install Autodesk® MatchMover™ 2014 Succeeded
2014/4/9:21:23:05 Charlie CHARLIE_PC Installing Autodesk® Backburner 2014: "C:\Autodesk\Autodesk_Maya_2014_dlm\x64\BackBurner\BackburnerCIF.exe" SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE="{44FFD99B-4877-4732-AA33-2FD3D7B622D2}"
2014/4/9:21:23:33 Charlie CHARLIE_PC Install Autodesk® Backburner 2014 Succeeded
2014/4/9:21:23:34 Charlie CHARLIE_PC PageOpen InstallCompleteDialog
2014/4/9:21:23:40 Charlie CHARLIE_PC === Setup ended ===
2014/4/9:21:23:47 Charlie CHARLIE_PC === Setup started on CHARLIE_PC by Charlie ===
2014/4/9:21:23:47 Charlie CHARLIE_PC Path_Length: 151
2014/4/9:21:23:47 Charlie CHARLIE_PC Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2014/4/9:21:23:47 Charlie CHARLIE_PC Launch
2014/4/9:21:23:47 Charlie CHARLIE_PC CommandLine
2014/4/9:21:23:47 Charlie CHARLIE_PC Current Directory C:\Users\Charlie\AppData\Local\Temp\_AI7690.tmp
2014/4/9:21:23:52 Charlie CHARLIE_PC === Setup ended ===
2014/4/9:21:23:50 Charlie CHARLIE_PC === Setup started on CHARLIE_PC by Charlie ===
2014/4/9:21:23:50 Charlie CHARLIE_PC Path_Length: 151
2014/4/9:21:23:50 Charlie CHARLIE_PC Current Directory C:\Users\Charlie\AppData\Local\Temp\_AI7690.tmp
2014/4/9:21:23:50 Charlie CHARLIE_PC Launch
2014/4/9:21:23:52 Charlie CHARLIE_PC PageOpen LaunchDialog
2014/4/9:21:23:55 Charlie CHARLIE_PC PageOpen BeginDeploymentDialog
2014/4/9:21:23:55 Charlie CHARLIE_PC CBeginDeploymentDialog::OnInitDialog reads PATH_LENGTH: 151
2014/4/9:21:24:02 Charlie CHARLIE_PC PageOpen LaunchDialog
2014/4/9:21:26:18 Charlie CHARLIE_PC PageOpen ProductInfoDialog
2014/4/9:21:26:47 Charlie CHARLIE_PC PageOpen ProductSelectionDialog2
2014/4/9:21:27:01 Charlie CHARLIE_PC === Setup ended ===
2014/4/9:23:06:22 Charlie CHARLIE_PC === Setup started on CHARLIE_PC by Charlie ===
2014/4/9:23:06:22 Charlie CHARLIE_PC Path_Length: 151
2014/4/9:23:06:22 Charlie CHARLIE_PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/9:23:06:22 Charlie CHARLIE_PC Launch
2014/4/9:23:06:22 Charlie CHARLIE_PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-24540564 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/9:23:06:22 Charlie CHARLIE_PC Current Directory C:\Users\Charlie\AppData\Local\Temp\_AI6060.tmp
2014/4/9:23:06:32 Charlie CHARLIE_PC === Setup ended ===
2014/4/9:23:06:24 Charlie CHARLIE_PC === Setup started on CHARLIE_PC by Charlie ===
2014/4/9:23:06:24 Charlie CHARLIE_PC Path_Length: 151
2014/4/9:23:06:24 Charlie CHARLIE_PC Current Directory C:\Users\Charlie\AppData\Local\Temp\_AI6060.tmp
2014/4/9:23:06:24 Charlie CHARLIE_PC Launch
2014/4/9:23:06:25 Charlie CHARLIE_PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/9:23:06:32 Charlie CHARLIE_PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/9:23:06:32 Charlie CHARLIE_PC PageOpen LaunchDialog
2014/4/9:23:06:41 Charlie CHARLIE_PC PageOpen LicenseDialog
2014/4/9:23:06:41 Charlie CHARLIE_PC PageOpen ProductInfoDialog
2014/4/9:23:06:41 Charlie CHARLIE_PC PageOpen ProductSelectionDialog2
2014/4/9:23:06:59 Charlie CHARLIE_PC PageOpen FullProgressDialog
2014/4/9:23:06:59 Charlie CHARLIE_PC Download Play MentalRayPlugIn http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/MentalR...
2014/4/9:23:07:07 Charlie CHARLIE_PC Download Complete MentalRayPlugIn http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/MentalR...
2014/4/9:23:07:07 Charlie CHARLIE_PC Installing mental ray® renderer for Autodesk® Maya® 2014: INSTALLDIR="C:\Program Files\Autodesk\mentalrayForMaya2014\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE={44FFD99B-4877-4732-AA33-2FD3D7B622D2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/9:23:07:34 Charlie CHARLIE_PC Install mental ray® renderer for Autodesk® Maya® 2014 Succeeded
2014/4/9:23:07:34 Charlie CHARLIE_PC Download Play Backburner http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Backbur...
2014/4/9:23:07:38 Charlie CHARLIE_PC Download Complete Backburner http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Backbur...
2014/4/9:23:07:38 Charlie CHARLIE_PC Installing Autodesk® Backburner 2014: "C:\Autodesk\WI\Autodesk Maya 2014\x64\BackBurner\BackburnerCIF.exe" SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE="{44FFD99B-4877-4732-AA33-2FD3D7B622D2}"
2014/4/9:23:07:51 Charlie CHARLIE_PC Install Autodesk® Backburner 2014 Succeeded
2014/4/9:23:07:51 Charlie CHARLIE_PC PageOpen InstallCompleteDialog
2014/4/9:23:07:57 Charlie CHARLIE_PC === Setup ended ===
