Installation & Licensing
Member
jtstear
Message 1 of 16 (36,021 Views)
ADR 2011-2013 Failed downloading Component
36021 Views, 15 Replies
03-30-2012 10:14 AM
No matter which version of Autodesk Design Review I try to setup I get
"The following failed to install:
Autodesk Design Review 2013 (0x2: Failed downloading component.)"
I am running this as local administrator and the setup works on all other computers.
The specific computer is WinXP Pro sp3, 2gb RAM, 2.09 GHz.
Machine has all updates.
I downloaded the bundle rather than the single install and it ran just fine.  Not sure what is different in the bundle than the single ADR install but it was needed in my case.
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10336080
This should link you to a 724MB download of the bundle.  I also ran a .exe not a .msi.  Good Luck! Let us know if it works for you as well.
Member
jtstear
Message 2 of 16 (35,990 Views)
Re: ADR 2011-2013 Failed downloading Component
03-30-2012 11:47 AM in reply to: jtstear
Active Contributor
brian_shick
Message 3 of 16 (35,897 Views)
04-03-2012 08:03 AM in reply to: jtstear
We are having the same Failure issue.  Where can we find the bundle download? I only see how to download the 2013 Design Review file located off the main Autodesk web page.  Would you include a link to the bundle location?
Brian
Member
jtstear
Message 4 of 16 (35,881 Views)
04-03-2012 09:25 AM in reply to: brian_shick
Member
anders.newfarm
Message 5 of 16 (32,872 Views)
09-05-2012 02:53 PM in reply to: jtstear
That was EXACTLY what i needed, thanks a bunch, that bundle saved my day!!!:smileyhappy:
Been testing and looking and searching and what not for hours, this was perfect.
Originally had the internet connection failed error, tried to uninstall the Akima whatever, then the IMO (?) version with no luck, this was the solution
Thanks again
Valued Contributor
PencilsWereSoEasy
Message 6 of 16 (31,951 Views)
10-17-2012 07:15 AM in reply to: anders.newfarm
not sure if it's still this way, but i noticed (maybe a year ago) that the design review installer reached out to the microsoft .NET site to downlaod components.  when you hit that site normally, it's pretty slow to respond and hence the DR installer times out and throws the error.  i don't know why companies like autodesk don't jsut make the bundle available straight away.  (back in the day it was called hotlinking and it was bad nettiquette :smileyhappy:
______________________________
~ "if this were /. this would be funny"
Active Contributor
brian_shick
Message 7 of 16 (31,948 Views)
10-17-2012 07:45 AM in reply to: PencilsWereSoEasy
there is a full bundle out there. i think you have to search for it under design review install. i am out if the office traveling today otherwise i would attach the link. i agree, thus should be easier to install for folks that have limited internet access like our surveying department... i will send you a link to the web download as soon as i am able to... Brian Shick Wk: 719-520-4628 Cell: 713-385-2431
Member
jtstear
Message 8 of 16 (31,947 Views)
10-17-2012 07:51 AM in reply to: jtstear
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10336080 is the link to the download.  This was posted awhile back.
Valued Contributor
PencilsWereSoEasy
Message 9 of 16 (31,942 Views)
10-17-2012 08:07 AM in reply to: brian_shick
thanks brian - yeah i know it's out there (as mentioned, it's linked in the comment above mine).
i just wish they'd put the bundle right on the main page, was really my comment.
New Member
GERRYVANN4374
Message 10 of 16 (23,175 Views)
08-23-2013 06:32 AM in reply to: jtstear
I tried teh download but that did not help.  WHat did though was disabling Trend Micro on the PC while installing AutoCAD.  I read that fix on another site and tried it - it worked!
