Just a bit of a follow up on Kevin's answer.
He is extremely correct in stating that if you use the Pre-2k2 version of
the adlm (elan) won't (or shouldn't, reliably) work with a multi-homed
system. Now the post 2k2 adlm (FlexLM) will work on a multi homed system
and is only dependant on the ethernet addr of the network card that you want
to use for the adlm (this is good). What I usually do on a multi-homed
system is to ping the ip addr (since the FlexLM communicates over tcp/ip, it
should have an ip addr) from an NT based (NT, 2k, XP Pro, or anything that
can do an arp) client and after the ping type arp -a (since this involved
typing in a win system I'm assuming that you know I mean at the command
prompt. For more information see
http://www.fsb-ae.com/acadnetwork/acadnetworkfaq.htm#3c and scroll down a
bit) and you can get the ethernet address of the card that you just pinged.
hth
jason martin
frankfurt-short-bruza
Kevin Nehls
wrote in message
news:EFDFF8FAD501419FAC11C91D458DCC31@in.WebX.maYIadrTaRb...
> First things first. Are you using AdLM or
> FlexLM? They are 2 completely different
> animals.
> If you are using AdLM, you're out of luck as
> you can't use it reliably on a multi-homed
> machine, nor can it be used reliably on a
> machine with a dynamic IP address.
> If you are using FlexLM, I don't know the
> answer. Hopefully someone else does.
> hth
> Kevin Nehls
> "Paul Bomboy" wrote
> in message
> news:3C03E407.FAB8A456@prbcomputers.com...
> > When I installed the ADLM using the licmgr
> program found the 1st NIC in
> > my server (this is a token ring card). I
> need to be to override the
> > value so my licmgr will funtion with the
> Ethernet card. My lic file
> > contains the MAC of the token ring card.
> What do I need to do to
> > correct this problem?
