Hi I have installed the student version of Maya 2015. When I launch maya I have this error message
"AdlmInt Error: The AUTODESK_ADLM_THINCLIENT_ENV XML file could not be loaded
license problem in GUI mode launch dialog message"
I went on the web hoping to find a solution (http://3dgumshoe.com/maya-license-was-not-obtained/) , unfortunately the issue has not been solved.
Any help would be appreciated
thank you
I am having the exactly the same issue 😞
PLus when I install everything, the application manager won't install, it fails.
