Are you using dhcp on the server? Do you have more than 1 network card? The adlm server
must have a static IP address to maintain the server code. If you have more than 1 network
card the machine can bind in whatever order it pleases and change the server code at will.
hth
jason martin
assistant idiot
frankfurt-short-bruza
www.fsb-ae.com/acadnetwork/acadnetworkfaq.htm
"jrich72" wrote in message news:f089d6e.-1@WebX.maYIadrTaRb...
> I have ADLM on a W2K machine, it seems that often my server code will change, and each
time this happens ADLM stops functioning properly. What can I do to correct this?
