Installation & Licensing
tcorey
260 Views, 1 Reply
ADLM on Virtual Server
I know we can install and run ADLM on a virtual server, but I am unclear when obtaining the license file if we are to use the virtual MAC address or the physical MAC address.
Thanks in advance,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
1 REPLY 1
david.lau
in reply to: tcorey
Typically, I have noticed that you should use the actual nic card and not the virtual nic card.   The best answer is to use the actual ethernet value that will show up in lmtool.exe.
You can download the NLM for Autodesk (step 1) and review the licensing process from start to finish here:
http://upandready.typepad.com/up_and_ready/2011/11/quick-start-setting-up-a-license-server.html
David Lau
Administrator Productivity
