Installation & Licensing
146 Views, 1 Reply
ADLM_Borrowmax
I'm trying to find the location for the variable to set the ADLM_Borrowmax. I changed this at one time, and I can't remember how to modify it. Could someone be so kind to give me an explanation again? Thanks, Greg
1 REPLY 1
Greg, ADLM_Borrowmax is set at the workstations. ADLM_Borrowmax is documented in the Network Licensing Guide on your AutoCAD 2004 CD. It only works with the Autodesk borrowing utility supplied with AutoCAD 2004, it does not work with in product borrowing as implemented in AutoCAD 2005 products. If you are using AutoCAD 2005, set MAX_BORROW_HOURS in the FLEXlm server's options file. MAX_BORROW_HOURS is documented in section 5.2.14 of the FLEXlm documents installed with FLEXlm version 9.2. -- Jerry Milana, Autodesk Consulting "Greg Barfield" wrote in message news:41235d19_2@newsprd01... > I'm trying to find the location for the variable to set the ADLM_Borrowmax. > I changed this at one time, and I can't remember how to modify it. Could > someone be so kind to give me an explanation again? > > Thanks, > Greg > >
Administrator Productivity
