Not quite sure what I did wrong during deployment creation. I followed the directions for creation here:
- When this is extracted to c:\autodesk\Autodesk_Revit_2015_R2, it contains a patches folder with DynamoInstall.msi, IronPython and RVT2015UR4.msi
3. Download Autodesk_Revit_2015-x64_Update5_forR2_Deployments.exe and save it to the same local folder as in Step 1
4. Start the Revit deployment creation or modification prodcess.
- *process
5. Expand the Additional Software section on the Product Selection page.
6. Add Autodesk_Revit_2015-x64_Update5_forR2_Deployments.exe by finding the folder where you saved the update (EXE) file.
- in my mind, this should update the software to Release 5, 20141119_0715
7. Optional: Specify /q in the Command Line Parameter field to run this install silently
8. Add Dynamo.msi by browsing to C:\Autodesk\Autodesk_Revit_2015_UR5_R2\patches.
9. Add IronPython-2.7.3.msi by browsing to C:\Autodesk\Autodesk_Revit_2015_UR5_R2\patches.
- In addtion to adding these to the Additional Software list, do we also have to add an .msp for the UR5? I have tried adding the RVT2015UR4.msi to the Service Packs section, which shows up as Revit 2015 Version 5. I have also tried not including the RVT2015UR4.msi and it make the build wrong too.
8. Collaspe the Additional Software section and complete your deployment setup.
-*Collapse
What am I missing to make my deployment Revit 2015 R2, Update Release 5?
Jroper
Hello. First, I understand how this is confusing. It is a puzzle of sorts. These are the build numbers for Revit.
2015: |
First Customer Ship |
Build: 20140223_1515 |
Update Release 1 |
Build: 20140322_1515 |
Update Release 2 |
Build: 20140323_1530 |
Update Release 3 |
Build: 20140606_1530 |
Update Release 4 |
Build: 20140903_1530 |
Release 2 |
Build: 20140905_0730 (Subscription only release) |
Update Release 5 |
Build: 20141119_1515 |
Release 2 Update Release 5 |
Build: 20141119_0715 (Subscription only release) |
The process for including all the updates is here:
There are no MSP files that I am aware, just MSI files, that extract when you run the EXE.
Thank you for taking part in our community!
