Installation & Licensing
Add Autocad Mechanical to Product Design Suite Premium 2014
5 REPLIES 5
mikeh7
761 Views, 5 Replies
I have a deployment installed on many PCs and w/ that, installed Acad Electrical which is fine.  I also need to get ACAD mechanical to those machines and want to do it by adding it to the original deployments.  How do I add ACAD Mechanical to the deployment as no where does it give me the ACAD Mechanical option in the Modify Deployment set of dialog boxes.  See the attachement.
I thinking about copying the ACADM folder to the image location for the deployment, and with in the deployment try adding it to the INCLUDE OTHER SOFTWARE option, but it doesn't make sense that I would need to do that since it's included in the suite.
Or do I make a deployment just for ACAD mech?
Thanks!
5 REPLIES 5
asburyj
in reply to: mikeh7
When modifying an existing deployment you can chance configuration and remove software but you can't add software that wasn't selected when the deployment was origionally created. What you will need to do in this case is recreate the deployment from scratch if you want both installs on one deployment. Alternitively you could just create a second deployment with AutoCAD Mechanical only.
Jeffry Asbury
mikeh7
in reply to: asburyj
Thanks Jeffrey - That was my assumption.  Can we make that a wish, to be able to add to a Deployment.
In regargs to creating an ACADM deployment, most of the machines will have ACAD E on them, will it mess with those installs at all, thinking in terms of menus and profiles.
Thanks much!
asburyj
in reply to: mikeh7
I don't think this is ever going to happen. To be able to add software post deployment uysing modify the deployment would need to copy in all the software regardless of if it was selected or not when the deployment is created. This is going to upset people who are concerned about the size of thier deployments residing on the server and it will also increase the time required for all deployment creations of suites.
Jeffry Asbury
mikeh7
I always thought it was odd to download the software, then create a deployment that duplicates a select amount of software in another location and as your create another deployment it creates another copy of the software.....
Why not download it where the deployment resides and the deployments reference that data instead duplicating over and over which kills server capacity.  Same with the S/N licenses when we have a blend of Suite Std, Suite Prem, and Suite Ultimate - for the most part they all copy the same data repeatedly and the only difference is the S/N in the deployment, but the each have there own download and own copy of the software for the deployments.
Obviously I'm not a programmer and am on the outside looking, but seems a bit contradictory on saving space and perhaps there's other caviots that require it be that way.
Thanks Jeffrey
david.lau
in reply to: mikeh7
There is a tiny little check box that you need to check on when creating a deployment to always include ALL the software.  It is noted here:
http://upandready.typepad.com/up_and_ready/2011/07/design-review-2012-deployment.html
This is a cool post too...
http://upandready.typepad.com/up_and_ready/2013/09/quick-start-suite-deployment-tips.html
David Lau
Administrator Productivity
