Installation & Licensing
z26j487
259 Views, 6 Replies
Activation
I have my product downloaded but am unable to activate it. I have tried everything that the autocad help area has on their hompage but nothing works. Any ideas?
6 REPLIES 6
bjo
in reply to: z26j487
Try this link: http://usa.autodesk.com/support/installation/
It's important to know if you have a singel license or a network license. Different ways to activate these.
Kr
Bjorn J.
Kind regards
Bjorn J.
JDMather
You have not supplied any information here about what problem you are having with activation.
Be specific.
Include screen shots if appropriate.
Exactly what step are you getting stuck on?
You say it is downloaded -- but you never state if you extracted and installed the program.
Is it installed and running normally in 30-day trial mode?
Is this a student license?
More information is needed.
z26j487
I have the program downloaded and running with the 30 day trial. The problem is when i open the program, Autocad 2011, i have the option of try or activate. I click activate and get a blank screen that pops up with what looks like two check boxes but there is no writing. This is where the problem is, i am trying to run it as a student also if that is helpful.
Patchy
z26j487
in reply to: Patchy
i've tried those and none of them work, I have no idea where to go from here
TravisNave
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Autodesk Forums:
Administrator Productivity
