Installation & Licensing
Activation Wizard doesn't appear on startup.
5 REPLIES 5
LesWoolsey
2959 Views, 5 Replies
I installed Revit Arch 2013 and requested an activation key  which I have since received by email.  But when I start Revit, the Activation Wizard doesn't appear so I can't enter the activation key.  Any ideas on how I can enter the activation info?
Les
5 REPLIES 5
Hi LesWoolsey:
Here are some helpful information on how to activate your serial number:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17971157&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18513720&linkID=9240617
For activation issue, please contact our Registration and Activation Team directly for assistance or call them at the following numbers:
Americas: (800) 551-1490
Europe / Middle East / Africa: 65.6735.5688
Asia / Pacific: 41.32.723.9595
I hope this helps.
Best Regards,
Arlin Bibat
aaronhai
in reply to: LesWoolsey
Hi LesWoolsey,
If you only have single product installed in your machine, please delete the Licensing info (adsk*.data file) to force re-activation.
To delete the licensing info, please backup and remove these files:
On Vista or Windows 7
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data.?backup
On Windows XP
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data.backup
Please let me know if that works.
Thank you.
Aaron Hai
LesWoolsey
in reply to: aaronhai
After moving those files out of the way and starting Revit, I was asked about joining the quality feedback program and then Revit continued.  I saw a small Window shich said it was checking the licensing but then that box disappeared and  I did not get the activation wizard.
I had already gone through  those pages and they offered no useful information regarding this problem.
I do have exactly the same problem, I've downloaded Revit and AutoCAD Architeture 2014 on student basis , Revit works properly but the activation wizard for AutoCAD Architure don't appear at all. when I click or double click on the icon (on desktop screen) nothing happens. please somebody prompt me with the solution
Thanks, Hamid
Administrator Productivity
