is "Windows to Go 8.1" a virtual machine? Never heard of it so am just curious.
If so, while Acad might work OK, while I don't have any experience with Revit thru a VM, I explored using Inventor thru one and all I can say is good luck! The performance wasn't acceptable if you really want to dig in and use the software. For learning it might be fine though.
nope this this isn't going to work
since the computer hardware is changing the activation will be broken everytime you plug in the usb into another machine
this will probably work with Network licenses
DarrenP
