Installation & Licensing
activation of product Autocad 2010
3 REPLIES 3
aapatel29
1807 Views, 3 Replies
I installed Autocad 2010 in my Laptop, with the serial number and product key.
At the time of running, it was failed to activate due to serial number is not ok. can u pls inform me the serial number mentioned on the box, it also make the thinga like this.
Can u please check and reply ,me ASAP.
regards,
Amit Patel
3 REPLIES 3
jerome.pineau
in reply to: aapatel29
Hi Amit, I've moved your post here as it will get quicker attention within that board.
Best,
J.
Jerome Pineau
AutodeskHelp | Social Media Strategist
twitter.com/AutodeskHelp
jerome.pineau@autodesk.com
TravisNave
If your product was upgraded and not kept under active Subscription, the lease probably expired.  If you never activated a newer version, you might be able to still get an activation code.  Perhaps philip.s can get you started on that.
Autodesk Forums:
philip.s
in reply to: TravisNave
I certainly can Travis 🙂
Amit, as I was unable to find any licenses associated with your registered email, can you please send me Private Message (click on my philip.s profile name and then "Send this user a private message") with the serial number that you had attempted to activate with as well as any additional relevant information.
Administrator Productivity
