Traduction ITA->Eng
Hi omassnc:
Please send me your serial number through private message(envelope next to your account name at the top of this page) so we may validate. In order to generate an activation code we will need the request code that is displayed on your monitor after you begin the activation procedure. Following are the steps to retrieve the request code:
1. Run the program
2. Pull down menu 'Help'
3. Click on 'About'
4. Click the Production Information button at the right hand corner
5. Click on the Activate button
6. On this page you will be able to view Product, Serial Number and Request Code
i'm not ready to send the information you: the browser in the private message reply:
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and send the message when you are satisfied
-ITA
Ok, ci sono riuscito! Penso che c'era codice html negli appunti che avevo incollato e il browser si era bloccato...
Scusa se ho mandato solo le foto per ridurre il testo al minimo...
-ENG
Ok, I made it! I think there was html code that I pasted to the clipboard and the browser was locked ...
Sorry I only sent the photos to reduce the text to a minimum ...
